48 brake drums removal
Started by dukjupiter, March 01, 2009, 12:19:10 PM
Here is a home made on.  A welding shop could make it up from scrap for cheap.
http://www430.pair.com/p15d24/mopar_forum/showthread.php?t=14132
The other option is to back off the castle nuts a couple turns, put the cotter key back in and drive till you hear them pop loose.
Go to the home page of the POC website you should find a link to Dave Pollack's article about pulling the rear drums.
I followed his advice last Spring with the rear hubs on my '40 P-10 Business coupe, his advice worked fine for me.
Hope this helps,
You definitely need a puller. Search for a topic rea brake drums in this forum. You will find ethe puller.
Look technical discussion, 21.Feb. topic 51 rear brake drums too!
Greetings ! Go
dukjupiter
need a little help.  got a wheel cylinder leaking right rear on my 48 plym special deluxe coupe and thought i would rebuild or replace them. how do i get the brake drums off the rear. do i need a puller? i dont want to bust anything.  thanks in advance, let me know.
1938 plymouth bus coupe
1948 plymouth coupe
1966 plymouth satellite conv 440HP
1969 plymouth roadrunner conv 4 speed
1960 plymouth bevedere 2door hdtp
