changing flattie for a poly
Started by virge55, September 23, 2008, 06:57:05 PM
Quote from: David Pollock on November 04, 2008, 12:25:54 PM
I would swap in a 318 and automatic from a 70s or 80s Chrysler product and the rear axle from the mid 60s. An upgrade of the front brakes would be in order too.?
If you are going to try to upgrade the power plant in your car you should consider Pollock's suggestion. The late model 318's and auto trans would be more reliable, friendly to modern fuels and not involve any additional work. The best way to accomplish the swap would be to have the complete Chrysler/Dodge that the engine is coming from.
In the long run the best solution to an underpowered car is to sell it and buy a car that has the power you feel you need. Your wallet won't suffer quite as much of a draining...Bill
Eddie M
I'm answering late Virge, but what did you wind up doing?
The poly engine is a good gutsy engine and as far as transplanting it to your car, it's not all that hard.
Let me know the update.
Life is what you make of it.
What you are proposing is not impossible, however, be warned,  it is not a bolt for bolt swap. The V8 cars use different steering linkage, and the rear crossmember may be in a different location. If you are truly going to succeed, get the rest of the car that the Poly came out of so you have all the appropriate bits and pieces.   Frankly, if it were my projec,t I would swap in a 318 and automatic from a 70s or 80s Chrysler product and the rear axle from the mid 60s. An upgrade of the front brakes would be in order too.  I do not have any trouble on US and Canadian freeways with my 6 cylinder Plymouths, are you sure yours is "up to speed"?
I might suggest that you post this same question on the p15-d24 website
virge55
Hi and yes some folks may say im mad ??? dont get me wrong i like the flattie but its a bit gutless(sorry) and im gettin carved up on the british freeways? and have been offered a poly from a 55 savoy that has a manual gear box now the question...
how easy or what is the best way to repace the flattie with this mill? i still wanna keep the powerflite trannie so will i need an adaptor plate? will this idea work? has anyone done this? have i lost my mind?? im sure that the 260ci hi-fire poly would have been mated up with my box but really need some tech help on this as i just got the savoy on the road and dont fancy a long layup again
thanks
virge
