turn signal wiring for a '41 coupe
Started by captbrian41, September 08, 2008, 11:38:08 AM
Yes, each lamp needs it's own wire and yes flashers are voltage sensitive.
captbrian41
Hi All, have the wiring diagrams for both the '41 coupe and Foxton's turn signal device but having trouble deciphering the connections. The rear lamps are a single wire and do I have to split them and run a separate wire back to the turn signal device. The front seems to take care of itself if I use the headlight terminal block. I also need a flasher and was wondering if flashers are voltage sensitive or will any flasher work for 6 or 12 volts? All help on the complete installation would be helpful and appreciated as I'm sure I will run into additional difficulties down the road.
thanks in advance
captbrian41
