Change from 6V to 12 V 55 Plymouth Belveder
Started by wiltoole, August 07, 2008, 05:01:44 PM
For 12V Radio, GPS position systems, cellphone etc You better get a 6 to 12 V converter. Some deliver 10 Amps (and consume 25!). They however cannot work at full load if very hot (under dash in summer), because of a safety temp device included.
Unless you have a specific reason, like the use of a modern stereo system, there is no advantage to conversion.  My philosophy is, if you can not get there with 6 volts positive ground, you don't need to go.
Doran Johnson
That is a topic that has been discussed here many times.  Not that some new points can't be made, but if you use the "search" function on this site with one or two key words, you should be rewarded with a plethora of views on this topic.  Have fun!
Doran
wiltoole
Can anyone tell me the pros and cons of changing the electrical system from the original 6V to a 12V?  I have a 55 Beleveder.  Please respond to my personal email, .  Thank you
