Just Curious
Started by Ed_Ungerman, July 24, 2008, 03:49:59 PM
Ed_Ungerman
Look forward to seeing you there.
1937 Plymouth Business Coupe
2005 Dodge Hemi Magnum
2000 Dodge Dakota 5.9 R/T
Well since I posted a smilar post a couple weeks ago (67+ views 0 responses)  I will be the first to answer yours.  I will be attending the POC meet in Detroit.  Will be traveling in our P 15 Business Coupe.  Looking to meet up with some folks from the P15 D24 forum, as well as make the aquaintance of others.
We are leaving central NY early Wednesday AM, to beat the heat and the traffic, an will likely arrive in the Auburn Hills area in the mid afternoon.  Hoping to get to the WPC museum, maybe do a cruise on Woodward Blvd.  Several of us will be doing a tailgate get together in the Hotel parking lot Friday evening.  If you care to stop by we'd be glad to have you drop by.
Will be traveling I 90 to Niagara Falls, then trough Cananda to Sarnia then to Auburn Hills.  Should any other northeasternes be traveling the same route we'd be glad to have your company on the journey if times coincide.
Hope to see you there.
Ed_Ungerman
How many on here are going to be in Detroit for the Grand National Meet starting July 30th? I'll be there, but not sure if my car will. Did some clean up, paint up, fix up (oil leaks). Decided to do an oil change before I started it up. Pulled the drain plug, and about a quart of coolant came out before the oil did.  :o Figured as the engine already needed rings and bearings (burning oil), I would just replace the engine. Got a good deal on a rebuilt P23 engine (cheaper than to rebuild mine) with zero miles since rebuild from Wayne Brandon (the Plymouth doctor). Just don't know if the switch will be done in time for the meet. I'll be the long-haired guy with the handlebar mustache walking around drooling all over the cars  :D with a camera permanently attached to my hand.
Ed
