went window rubber mouldings
Started by 12905, April 28, 2008, 08:28:59 PM
MRR41 COUPE
I used Steele Rubber for my vent windows  on my 41 ply coupe and they look and fit perfect
steele list 1941 front vent window weather strip for $139.40/pair,#40-0123-55
Thanks Lindsay. I'll contact Steele.
Brian
Lindsay McConnell
Personally, I always go with Steele Rubber Co.
They are the manufacturers of good, well fitting rubber replacement parts. Other companies buy from them the stuff that is not quite up to specs. but not bad enough to scrap. Why tear your hair out with the stuff that is just not up to speed, when you can get the stuff that fits as it should?
Yep, you pay for it, but is it not worth it in the long run?
A friend need vent window rubber mouldings for a 41 US Plymouth 4-dr. Any suggestions as to likely sources?
All help will be greatly appreciated.
Brian
