Turn Signals
Started by Carmen, March 17, 2008, 01:00:45 PM
Don St Peter
I'm installing turn signals on my stock 40 Ply P-9. Using the 7 wire turn signal from NAPA and a 6 Volt flasher. I will utilize my existing park and stop/tail lights to serve the purpose to avoid adding something that is non std.? I will run 2 new and seperate wires that will splice into the Rt & Left park lights existing wiring somewhere before the terminal block stud where the lights get power from the headlight switch. The other ends of the added wires will tie into the respective wire of the turn signal. True these small bulbs are single element, however they are only on when my headlight switch is in the mid position. The full out headlight switch position, turns off the park lights and turns on the headlights. This then makes them ( park lights) available fot the turn signal function anytime they are needed. I may paint them with an amber paint for proper color.
I will then splice into the non-hot wire going out of the stoplight switch. The other end of this single wire will go to appropriate wire of the turn signal. Of course my car does have the dual element rear bulbs and no changes will be made. The bulbs will now serve 3 functions; tail lights, stoplights, and turnsignals. The stoplight and turnlight function will be served by the bright element of each bulb.
The flasher will be wired into the turn signal per the provided diagram.
That will do it, except I may find some 6 V hi intensity bulbs for better brightness. Good grounding will remain on the top of my list
Don St Peter
PS: I too note that # 3 & # 4 are mislabeled.
Don
Blue-Skies
This is the same diagram that came with my el-cheapo turn signal kit from Rod-n-Custom.  Took me a while to figure out why my left front park light was coming on with the brakes, and no brake light at the left rear...
Wires #3 and #4 are mis-labled on the diagram....
Pete
Quote from: Don Coatney on March 17, 2008, 01:16:30 PM
After market turn signal units can be found on the bay and through various vendors. Here is a 7 wire schematic.
Willys Discussion forum
www.oldwillysforum.com
Carmen
Dan
Thanks for the diagram. Is there a name brand or madel that I need? or will any brand do?
Carmen
Don Coatney
Don Coatney
Carmen
Ok you guys have been giving me looks of help now I need more help. I have a stock 1941 Plymouth P12 I want to add turn signals to it.  Where can I get them, how are they hooked up and do you hook them up to the rear and front park lights?
Carmen
