MPG
Started by Carmen, March 15, 2008, 10:00:49 PM
See my earlier post on this subject.  I would not be content with mileage below about 18 mpg even when roaring around town in low and second gear, if that is even possible these days.
However, a sure fire killer of mileage, assuming the engine is in decent shape otherwise, is low vacuum at the power valve.   The first thing to check is if the carb has the correct gasket under it. The proper gasket has 4 indentations , so it can go on any way and connect up with the port on the base of the carb.
Next, check vacuum with a gauge. If it is low..... say 14 inches or less.......  look for retarded timing or vacuum leaks.
The center runner on the intale manifold is prone to crack and cause low vacuum but surprisingly it does not upset the running of the engine as much as you would think because the power valve enriches the mixture.  Similarly, a ruptured diaphragm in the spark advance or a leaky windshield wiper can do the same thing.
Last summer, my mostly stock '36 convertible was getting 8 mpg, after replacing the aging Stewart Warner electric fuel pump with a Carter electric pump from Summit Racing.
After some experimenting, after adding a fuel pressure regulator to the mix, I am now getting 13 mpg; the engine has about 110000 miles on it.
I like Tod Fitch's approach to driving in general and fuel economy; our '99 Accord (145000 miles, 4 banger, 5 speed manual, discs in front, drums in rear) is still on the original pads and shoes. We drive the same way Tod does.
Quote from: plym_46 on March 19, 2008, 07:38:36 PM
Looking at these posts it seems that the plymouth model number cosely corrolates to their fuel milage.  Coincidence or engnieering???????
I guess I am doomed to suffer with poor mileage since I have a P8. I thought my problem was a heavy foot and to much HP ::)....Bill
notdavidspade
darn,... should have bought a Chrysler 300!
Quote from: Don St Peter on March 19, 2008, 04:20:11 AM
Tod:
Your MPG is amazing. I have done many things to my stock 6 on my 40 Ply P-9 to get the MPG barely to 10.2 MPG. This includes a fully overhauled ( By Datona Beach firm with great credintials ) Carb.
Since I am planning a long road trip with it I even installed an overdrive recently. I works great, but I already know it will not come close to your numbers.
Whats your secret?
Don
No particular secret that I know of. My driving style is pretty mellow and I do try to anticipate conditions ahead. So for around town driving I don't waste a lot of energy heating up the brakes. I think anticipating things keeps your speed more constant, less energy wasted and thus better mileage than the average. Because of that I get a lot better brake life than most too: My 1991 Jeep went 200,000 miles with one change of front pads and original shoes on the rear and my 2004 Prius has about 50,000 miles on it as of the last service there was still 85% of the lining left on the pads and shoes.
On the highway wind resistance is the killer: Doubling your speed will quadruple the power needed to over come wind resistance. Which, assuming that your engine efficiency is relatively constant, means you will use four times as much gas. In practice your engine's peak volumetric efficiency is often close to normal cruising speed so the drop in mileage due to power requirements is somewhat mitigated by higher engine efficiency. In the old car my "highway driving" is usually touring back roads at speeds between 40 and 50 MPH which keeps the aerodynamic losses down and keeps me close to a good RPM as far as engine efficiency is concerned.
And I might be helped by the fact that I have the original 190 cu. in. engine: It just does not pump as much fuel/air as the newer larger displacement engines. It does mean that I don't have a lot of reserve power but I am used to that.
Don St Peter
Based on Plym 46 post you should expect around 12!
Don
Don
Don St Peter
Tod:
Whats your secret?
Don
Don
Quote from: Carmen on March 16, 2008, 10:41:56 PM
Since I have not done anything to this engine is there anything that I should be adding to it like lead?
Carmen
No lead needed. You have hardened exhaust valve seats from the factory. And a stock engine has low enough compression ratio that all it needs is regular gas, no high octane required.
However modern gas additives are unkind to older formulations of rubber so to be safe use a steel tipped float valve in the carburetor and rebuild your fuel pump using a modern diaphragm material and replace your flexible hose from the frame to the fuel pump with new materials. Do not use "new old stock" (NOS) or "new old replacement stock" (NORS) (i.e. vintage aftermarket) hoses. And if you get an NOS/NORS fuel pump rebuild it before you use it.
Back to the original topic: I am getting between 14 and 17 miles per gallon with the type of driving I do with my 1933 DeLuxe.
Carmen
Carmen
Never believe what people tell you about their gas mileage or their love life (unless they say they are not getting any)
I have gotten as much as 28 mpg from my 50 and 51 Plymouths   BUT  these amazing figures were obtained on a 240 mile interstate highway run , running on radial tires and in Overdrive.  I have backed up the results several times and checked the distance with a more modern car.   Both cars have increased compression (8.4 to 1.  With a stock 41 Plymouth running around town, 17 to 20 would be about as good as you can expect. The engine , a 201, is working pretty hard just to get the car up to speed. You would be amazed at how much more power (torque) comes out of a 230.  plym-46's reply offers lots of good advice.
14 to 17, these cars have low rear ends compared to todays cars.  they were designed when average speeds were in the 45 mph range.  They are low compression and today's gas doesn't like low compression engines.  You can help a bit by upping you tire pressure, and advancing you timing a bit 3 to 5 degrees advance over factory setting.  Also most folks seem to have good luck with auto light and AC spark plugs over Champions.  Also you should run a 180 degree thermostat as a warmer engine runs with better thermal efficiency.
I have a 46 business coupe.  With the stock 218 engine it never got more that 17, it never got less than 16.
Don't tell anyone but I have replaced the engine with a 230 out of a 56, I have milled the head and decked the block to up compression, I also am running dual carbs on a fenton intake manifold and (perish the though) non stock exhaust system.  I am running 225 75 15 radials on the rear tires at 34 lbs. and 205 75 15 on the front at 34 lbs.  On the highway I get 19 mph. running around town it gets 17.
Carmen
With the price of gas the way it is, I was wondering what the average MPG I can expect on my 1941 Stock Plymouth P12?
Carmen
