Chev S10 5 speed transmission in a 36 Plymouth
Started by 12905, March 12, 2008, 12:55:24 AM
Ed_Ungerman
T5 Overdrive Transmission Adapter
5-Speed Your Flathead 6!
The use of an adapter plate to mate the 4/6-cyl S-10 5-speed (T5) transmission to the Mopar flathead engine requires that you use the transmission with the longest input shaft and a clutch disc with a reversed offset hub to assure proper spline to clutch hub engagement. The input shaft also requires a special crankshaft pilot bushing.
Our kit includes a machined aluminum adapter plate w/flat head machine screws, a clutch disc with a reversed offset hub, a longer clutch pivot bolt and an Oilite crankshaft pilot bushing.
The popular transmission is the S-10 because its design offers the forward mounted shift lever. Its location is about 11? back from the flathead clutch housing or the early floor shift location. And, the S-10 tail housing can be installed on all T5 boxes.
The adapter plate is 5/8? aluminum, blanchard ground and CNC?d to accurately mate the T5 to the stock clutch housing.
The clutch disc is a GM 9-1/4? disc with an offset spline. The hub has been reversed to get more of the S-10 input shaft into the disc. The pilot is a high-quality Oilite bronze bearing.
You are to supply your own clutch throw-out bearing and sleeve (collar). The stock Mopar clutch throw-out bearing and sleeve can be used by honing out the sleeve to match the S-10 bearing retainer. Or, the retainer could be turned down to mate to the sleeve. An alternative would be to press a sleeve over the stock S-10 bearing retainer and machine to accept a 1994-2001 Cherokee throw-out bearing assembly. This will mate to the later stock clutch fork. Another alternative is to use a Ford bearing retainer, which will accept the 1994-2001 Cherokee throw-out bearing assembly. The mounting flange on the Ford retainer needs to be turned down slightly to match the S-10 for piloting into the adapter plate.
Before starting this project it is recommended that you become familiar with the B-W T5 transmission. There are many sites that cover the history of this design and give good information on its flexibility, available gear ratios and applications. You should also confer with a T5 specialist such as Tom Langdon in Utica, MI (586-739-9601) when you are ready to buy.
Buyer concerns: Transmission to chassis mounting Emergency brake relocation Driveshaft modifications Speedometer (mechanical available on pre ?87 S-10s) Shift lever position (approx 11? back from stock)
Kit cost is $295.00; postage inside USA is $17.00.
Check, M.O. or Paypal to
Price good until 3/30/2008.
Paul Curtis
19319 Candlelight
Roseville, MI 48066
586-296-2488
Call Paul at the above number. He should be able to answer all your questions.
We will be remembered by the tracks we leave behind.
1937 Plymouth Business Coupe
2005 Dodge Hemi Magnum
2000 Dodge Dakota 5.9 R/T
dukjupiter
i've got a 38 plym bus coupe. any particular year s-10 trans that i need to get or stay away from and where do i get the adapter and what all else do i have to do? thanks in advance, i need all the help i can get, i am as dumb as i look.
1938 plymouth bus coupe
1948 plymouth coupe
1966 plymouth satellite conv 440HP
1969 plymouth roadrunner conv 4 speed
1960 plymouth bevedere 2door hdtp
12905
Thanks guys for the great help. I really appreciate it.
Brian
Don Coatney
Follow this link for pictures of how I did it in a P-15. I have driven about 15,000 miles with this setup up and no problems to date. With the 30% overdrive reduction and a 3.55/1 differential I can run 70 MPH with my engine turning around 2200 RPM's. I also upgraded the differential from a 74 Charger and this fixed my emergency brake issue. I do have a long block Desoto flathead engine in my car.
Don Coatney
Ed_Ungerman
Wayne
Go online and look up genie shifters and also I think Hagen has e-brake setups that look almost like the original hand brake lever. Grab a hotrod book and you will find adds in most of them.  Wayne from California
12905
My memory is really poor, but I know that I read somewhere - either on the POC or the WPC - that a Chev S10 5 sp can be installed behin any generic DPCD 6 cyl non fluid drive flathead. If this is so, does anyone have suggestions re the installation of a hand brake to replace the original? I'll really appreciate any comments/suggestions.
Brian
