Brake line Set
Started by martin, February 26, 2008, 02:36:39 PM
Good advice from David. You should also consider getting a tubing bender. It's an inexpensive tool, and allows you to pretty accurately follow the factory routing of the tubing. If you like neat, clean results a bender is essential.
Brian
Auto supplys sell a variety of lengths of brake tubing. The 40 uses 1/4 inch.  Buy tubes that are a little longer than needed,( it is sometimes possible to get an exact fit)  and get yourself a double flaring tool. It takes only minutes to cut and reflare the tube. It is easy to do, but must be "double" .  An insert makes a bell shape of the line end, then it is removed and the tool completes the flare.  Simple and inexpensive. ( Do not use copper tubing on brake lines. )
Pandanom
Quote from: martin on February 26, 2008, 02:36:39 PM
Does anyone know where i can get a brake line set for my 1940 plymouth P10?? ???
Try nick at
Call InLIne tube- they may have a set in their computer.  I sent them my old ones and they made a stainless set for my PB for around $250 and they fit perfectl;y.    1 800 385 9452.  they also made a set for my 72 LandCruiser, and when I got aound to installing them a year later, a couple of pieces were two short and they made them good at no charge.
Martin, I got mine from Roberts, a couple of years ago. He states to sell for 1928 to actual cars.
Parts were a perfect fit. Greetings! Go
I would expect that you will have to have them made at a local shop
That is what I had to do with my '40 Plymouth years ago
martin
