brake hub
Started by virge55, January 16, 2008, 10:23:20 AM
virge55
Hi to all
thanks for the replys to my question been heaps busy and no time to reply,
i got the brakes workin after some trial and loads of error just needed to get the adjustment right I cut slots in the anchor bolts and put the drum on and kept playin with it till something happened!! well nothing did untill i adjusted the master push rod ( as it's a new master) and "bingo" brakes!! so thanks guys hey im almost there should be on the road real soon, ;) man i cant wait!!!!
Pandanom
I am redoing my brake system on my '37 4 door sedan. I am not to the point of adjusting yet since I am waiting on parts but I have no idea what you all are talking about. How does an adjusting gage or dummy drum work? Please elaborate and tell a novice more. I want to do it right.
James
MikeH
Elmo,
I for one would be interested to see that brake drum.  I have thought
of using a spare I have to make an adjusting gauge.
Mike
Virge what are you going to use it for, are you going to make a dummy brake drum for adjusting , it is the way to go . like david i have several spares if i can find them amongst the other "junk" that i seem to keep. as david said it will be quite expensive for freight, as you will realise from what it cost to send the manifold to you , but it should be a lot cheaper from Canada  than NZ . If it is required for a dummy brake drum i can send you a pic of how i altered mine
I have more than one. Shipping (from western Canada) would be costly though.  any hub from 48 to 56 should be the same if you can find one closer to home, otherwise you may contact me outside this forum via the Plymouth Bulletin Tech advisors Column.
virge55
Has any one got a useless/broke/wornout 10" brake drum off a 55 mopar/plymouth need the hub
thanks ???
