Fast Flathead
Started by 57plymouth, December 04, 2007, 12:01:34 PM
Thanks again for the kind words, Pete.  It is only when the old six starts to sound like an anvil that I will run for cover.  With modern oils and common sense, these engines will run for a long long time.  Every time I drive my 50 Plymouth, I wonder why I actually own more modern vehicles.
Blue-Skies
Quote from: David Pollock on February 19, 2008, 05:49:27 PM
Glad to see there are still people out there that like the flathead. In my article Make That Plymouth Run, I outlined some performance mods which are simple. Upping the compression by milling or better still swapping cylinder heads  ... like a 218 head on a 230   or more displacement, or using a Chrysler 6  Porting the intake ports to match the intake manifold helps breathing a lot.
In 40+ years of messing with these engine, the nicest running is a Canadian 218   3 3/8 x 4 1/16   bored to 3 7/16 and ported with compression about 8:1.  Smooth, revs good,  and reliable.  Coupled to an overdrive you can keep up with any modern traffic.
David-
I poured over your article again and again when I was getting ready to build my engine...  It was the first thing I found on getting a bit more out of a flathead six.
I now have about 14,000 miles on my hopped-up six, and I love every mile.  With the overdrive, it is as drivable as any car on the road.  After getting a few bugs worked out, it's as reliable as an anvil, and gets 19mpg on the highway.
I'd post pictures, but for whatever reason they seem to crash the POC forum, so I'll post a link instead...  http://www.50plymouth.com
Keep the six, keep the faith!
Pete
Willys Discussion forum
www.oldwillysforum.com
Ping
I know of one little flat head 6 that doesn't need to be any bigger!! :0  I was traveling down an interstate a week ago.  This new Caddy with paper plates started by my 40 Plymouth Coupe, well the person driving the Caddy looked in the mirror to see if they could go back into line.  NO, I was right there.  Well we did this three times and the flat head 6 was traveling 72 miles an hour then.  When all of a sudden that new Caddy blew away.  Never did see that Caddy again.  But, what fun it was to show a car 68 years old could still strut its power down the interstate with the rest of the modern automobiles.....:)  Still Laughing! A little kid left in the ole people yet!!     Ping
virge55
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOHHHHHHHHHHHHHHHH BABY!
57plymouth
I decided to pick the Flattie up a little. Who says you need a V-8? Overhead valves are just a fad anyway.
http://bacooper.myphotoalbum.com/view_album.php?set_albumName=album17
Virtus Junxit Mors Non Separabit
