radio for 1940 Plymouth
Started by Ping, November 18, 2007, 11:54:35 AM
nydak
I have a couple motorala radio that will fit a 40 to 48, both need work if anyone wants them
furylee
The Model 800 is the correct radio for the 40 and the 41.  It actually fits all models Chrysler, Plymouth, Dodge, Desoto.
The model 802 (P-15 46-48) radio will work on the 41, but you need to cut part of the dash.  I saw this in some dealer info I read somewhere.  But the knobs, dial and push buttons are all in the same place, there?s just a recessed area between the dial and buttons on the 800.
37 Plymouth Deluxe Sedan
41 Special Deluxe Coupe
58 Belvedere Convertible
64 Fury Convertible
68 Fury III Convertible
Papillion, NE
Jim Yergin
I know from personal experience that a model 802 radio (1942-1948) would not fit in my 1941 P12 dash. I needed the model 800. Maybe the 802 can be made to fit but you would have to do surgery on the dash trim to do so.
Jim Yergin
They'll all fit from 1940 thru 1948.  I've seen many 40's with 46-7-8 radios in them....
I don't believe the '41 radio will fit the '40's. As I recall, I have an installation sheet that says the '41 radios will fit the '42/48 and the '42/48 will fit the '41's, but there is no mention about the '41 to '40 application.
It might be more likely that a '39 would fit a '40 because these cars are more similar in some details and they do share many parts and accessories.
Keep in mind that I am referring to original equipment 'Philco' radio's. I have a friend that works on old radio's, so any chance I get to pick one up, I do so, never can tell when a need for one might arise...Bill
Ping
Does anyone out there know if the radio for a 1941 Plymouth will fit in the 1940 Plymouths?  I think there is a little difference, but don't  know for sure.  Thanks, Ping
