question #1- 37 P4 dome light
Started by Chris in Jax, August 01, 2007, 11:24:05 AM
Ed_Ungerman
I just fixed the dome light on my P4 coupe. Lens just popped of with no problem ( just a slight squeeze on sides of lens). Bulb checked out OK, so I removed the On/Off switch. The wire connections were GREEN. I had an extra switch so I cleaned the bare ends of the wires and installed the new switch. Worked perfectly. In fact, my dome light seems brighter than my head lights.  :D
1937 Plymouth Business Coupe
2005 Dodge Hemi Magnum
2000 Dodge Dakota 5.9 R/T
Chris in Jax
need to check / replace bulb.? any secrets to removing the bezel & lens or can I just pry it loose carefully?
thanks,
-C in J
Chris Brown
Jacksonville, Florida
'37 P4 4-door Touring
'31 Ford Standard Coupe
