Pitman Arm 1933 PD
Started by pat69, August 28, 2023, 02:09:08 PM
Robert4
From Plymouth Master Parts List book, PC and PD have same part number, earlier years are different part numbers.  I dont know how 34 or later fit
pat69
Does anybody know the diameter of the sector shaft at the toothing for the pitman arm ?
Are there interchangeable pitman arms ?
Regards Patrick
Robert4
I have a complete steering wheel, column, gearbox, and pitman arm from a 33 in storage.  I Measured the ball with a caliper at 1" diameter, if that helps at all.
Quote from: Robert4 on September 02, 2023, 08:48:57 PMI measured a 1" diameter on this pitman arm.  Bob.
That sounds pretty big for the ball at the end of the pitman arm. I guess I need to pull the drag link off mine and measure it.
Robert4
If you don't get a reply after a while, let me now and I will go and pull the drag link on my car to measure the pitman arm ball diameter. Though I suspect that mine is no longer perfectly round too, just not enough to be really noticeable with the naked eye.
pat69
I own a 1933 PD and wanted to know the original diameter of the Pitman Arm Ball, mine is totally egg shaped....
Regards
Patrick
