29 U - Details Details.
Started by chetbrz, March 22, 2007, 01:48:55 PM
Thanks.., a very interesting read.
FourDoor
Fisher actually made bodies for Chrysler in the 20s. So this bulletin does depict a body assembly very much the same as the first 2 Plymouths. The  Ford Model A was made by 2 other body makers,Briggs and Murray and the construction is not the same. I'll try to load in a higher def. scan. This was only 150 dpi. It depends on how much Admin. will allow in one upload.
30 Ply 30U
The 4 cylinder meets are held somewhere different each year. This spring is Toronto, and the fall meet is in Maine. We have people travel from your area and further (trailer the car to the event of course). Give me a few days on the numbers.
Patrick
30U Sedan X 3
30U convertiable coupe
50 p-19 Bus coupe
Quote from: 30 Ply 30U on March 22, 2007, 10:00:27 PM
I am e-mailing you some VERY high res photos that you can zoom in on of two original 29 sedan unrestored drivers. Anyone with a 4 cylinder, ready to drive or not would find great benifet and enjoyment in attending one of the two annual driving tours that we hold. I hosted the last one, what a blast!
Sounds great but you're a long way from Virginia & DC.? But you never know...
30 Ply 30U
Patrick
30U Sedan X 3
50 p-19 Bus coupe
Quote from: Plymouths on March 22, 2007, 03:37:15 PM
I remembered I had this in my files. It's almost exactly like a '28/'29 Plymouth body.
Mr Plymouths,
Could you email me the full size jpg file.? That is a very interesting document.? Check my profile for the email address.? It is not hidden.?
Is that a New Modal A Ford Body.??  It looks like it...
Tks Chet...
Since I purchased this car I have been attending to a number of incorrect repairs or restorations items which were poorly done.? One particular item is how the windshield metal hood is mounted on my car.? It appears that the roof wood over the windshield was either incorrectly redone or was broken and incorrectly placed.? The bottom line is that the roof does not go over the top of the metal shield rather the metal rain shield is attached over the roof.? Hard to explain but this is what I am looking for.
A picture looking down on the windshield hood from the top so that I can determine exactly how much of the roof went over the metal rain shield. This detail should be easy to correct just need to see how it is suppose to be mounted.? I have a good idea but one picture is worth a thousand words.
tks,? Chet...
