Washers of rear axle needed plz Help!!
Started by plaza1954, November 25, 2006, 10:49:55 PM
Hi from New Zealand Milton,   three other places you might try (1) www.robertsmotorparts.com. (2) www.kanter.com. (3)www.agelessautoparts.com. i dont know if you have the parts No for these washers ,but looking at the parts book they can only be ,thrust washer No 632 587 these are the side washers. and drive pinion bearing washer front bearing No 856 871, drive pinion bearing rear No 665 237. the parts book says for the rear washer use as required and it can come in different thickness,s which to complicate things have different part No,s , and range in thickness from .084 to.100 . I hope this is of some help to you .
plaza1954
Hello gentlemen, Im working over the rear axle of my '54 plaza and the 2 flat washers that come down the differential side gears and the 2 concave ones of the differential pinion gears are wear out too far to be replaced.
Neil Riddle and Andy Bernbaum said they dont have them so Im fried.
So does anyone knows where to get those parts???? I would apreciate a lot any help.
thanks.
Milton V.
