12 volt overdrive
Started by 1953 plymouth, November 20, 2006, 09:23:55 PM
jd2ksilver
You can use a Napa HR201 or a Wells LR620.
Overdrive, best thing for this car.   ;)
John Davies
Mountain View, California
1953 plymouth
thanks for the info. did you used the same od relay?
jd2ksilver
I did mine and found a 12 volt solenoid from this guy.  New from Borg Warner, said he bought out all the remaining parts they had years ago.  Not sure about that, but this is definitely the correct part.  Works great
Don's Antique Auto Parts
510 792 4290
37317 Niles Boulevard
Fremont CA 94536
He's kind of a character, but he knows his stuff.
John Davies
1953 plymouth
has anyone converted to 12 volt and retained the overdrive on a 53 plymouth? i'm in the process of rewiring my car and i would like to here from someone that has done this before with good results. i plan on using resistors but i think there may be some 12 volt parts that will interchange but i don't know whats out there yet to make this happen.
