king pins and bushings
Started by elmo, November 12, 2006, 02:38:22 AM
Hi     quite often i log on to this sight and see some one looking for king pin (wristpin) sets.about 10 years ago i installed a new king pin set into my 37 Plymouth bodied chrysler.i have kept the box they came in , and have since installed the same set into my 54 desoto diplomat &my 39 s6 desoto, chrysler  did not change a lot of things over the years as the box states the same set will fit (i will only give you the Plymouth applications) but they also apply to chrysler , dodge &desoto .   Plymouth     1939-54(except 7 pass) 1954-57, P25/2, (after No 560) P25/3, P25/4 1956-58 ,utility, P25A/234. I think after starting this i had better give you the other applications as well.    Chrysler - 1935-39 c6,c7,c16,c18,c22  Desoto 1935-39 SF1,S3,S5,S6, 1954-57SP25/2(after No 584 sSP23/3 SP25/4,1956-58 utiity, SP25AM,/2-3-4  Dodge 1934 DR(afterNo 3681755)DSafterNos 4528655) 1939 D11,1940-48,D14,D17.D19,D22,D24 (to No 31006517) D25 except 7 pass), 1949-52, D29,D33,D41 1954-57,D49/2, after nO 1677),D49/3,D49/4 1956-58 utility,D49A/2-3-4.   As you can see these are from an aussie  after market supplier so i cant give you the original parts Nos, but it will give you an idea of the applications         Rex
