39 Plymouth Coupe Door Lengths
Started by RockabillyBoogie, November 24, 2005, 05:45:09 PM
RockabillyBoogie
Thanks Andy,
I'm converting a 39 4 door sedan to a 5 window coupe so the front doors stay the standard width and as for the Holden running gear well I am in Australia and Holden gear is easily available and very cheap compared to Mopar stuff.
Thanks again
Elvis.
RockabillyBoogie
Well I'm an Australiannad the 253 Holden engines are a good little unit, I already have the engine, gearbox and diff from a HQ Ute in reallly good condition. I would consider a Ford or a Chev in a Plymouth but the Holden stuffs ideal and fits perfectly. Im now converting the Plymouth sedan into a 5 window coupe with the 356 Ford look.
Thanks Elvis
From Australia
Andy Wylie
An Australian coupe is 1116mm below the centre hinge, I don't know about the US body pictured or why you'd want to put a GM powerplant in it :-\
P7 Utility Ch-Ch N.Z.
RockabillyBoogie
Hello Everyone,
Can someone tell me the door length of a 39 Plymouth coupe straight across under the hinges as per photo.
Elvis from Emerald Qld Australia
