196 Cubic Inch engine block water leak at exhaust valve port #2 cylinder
Started by Broke Chevy, August 11, 2026, 12:00:01 PM
Good to hear you got it fixed. That type of repair is far beyond my experience.
    The following users thanked this post: Broke Chevy
Broke Chevy
I fixed it. I welded the hole using a piece of 11 gauge steel. It took more than 3 attempts to fix before I put it back together. I ended up using JB Weld which is rated for up to 550 degrees F.  I smeared the JB Weld all over the welded parts. I'm amazed at how much rust is in the cooling portion inside the block and head. I cleaned the rust out the best I could. After getting it back together the engine no longer is spraying water out the exhaust when its running.
https://1drv.ms/i/c/0ac21b71935533d9/IQBJ6kJaN3LMRplkz2gTNYJvARxLtB_OYsqgmFJL8k-Seug?e=lwoJ6d
https://1drv.ms/i/c/0ac21b71935533d9/IQCfYSvPuWgYR7WFGdvfDanEAQRHuYZbZJiEdN_luEeQHxk?e=HgbKFx
Broke Chevy
Hay folks I have a question. Can this be fixed? Take a look at the videos. The leak is at the number 2 cylinder exhaust valve port.
https://youtu.be/GmY_GMakXzY
https://youtu.be/3A9dEIlTzvI
