51 Plymouth electrical / lighting / turn signal / rewiring front to rear
Started by bluestreak[delete this bit 6a5faa3e4191e][insert an at symbol here]citlink[insert a dot here]net, May 04, 2025, 09:12:50 PM
SteveR
Sometimes Chickens Sometimes Feathers
Paul McD
The last couple of pages of the service manual have detailed wiring diagrams.
Hope this helps
bluestreak[delete this bit 6a5faa3e417f6][insert an at symbol here]citlink[insert a dot here]net
My issue is that I cant get info on how to wire the car to make the blinkers brake lights to work properly.
Does anyone have a clearly defined wiring schematic?
Thank You very much!
