1937 Plymouth PT50 Woodie (Front Engine Mount Bracket Question)
Started by 1937Firewood, October 18, 2022, 09:58:56 AM
My 1933 has a similar metal support that holds the front motor mount and there is definitely no rubber between it and the frame. There are no rubber pieces for between that "Engine Front Support Plate" show in the 1936-1948 factory parts manual.
For what it is worth, the front engine mount which is on the top of that support plate, is officially a "Engine Front Support Insulator Assembly" and is part number 1115744 which was used on both Plymouth cars and commercial vehicles (i.e. PT50) from 1937 through at least 1948.
See part codes 9-65-6 and 9-67-4 in the factory parts book.
1937Firewood
Ops, got this from another person, showing that there is a motor mount in between ?
Which one is correct?
1937Firewood
Thank you, you can't believe how many people i asked and nobody had a clue.
Again, very much appreciated.
Time to stuff the motor in.
Cheers
Z
No, that support bolts directly to the frame. The motor mount is that flat piece with rubber at the top.
1937Firewood
Please look at the photo, does this front engine mount bracket need 2 rubber type mounts between this piece and frame?
Or does it bolt up to the engine and frame the way it is?
FYI:
I bought the car in pieces so i have no idea and any help would be appreciated.
You cannot view this attachment.   Getting ready to stuff the engine into the car.
