1933 PD 4 door rear window drain location
Started by merric33, October 17, 2022, 10:01:41 PM
The rubber flaps were long gone on my car.
By the way, safety glass was optional on the side and back windows and I had the pleasure of having one of my side windows shatter while I was driving. Take a look at the edge of your glass to see if it is safety glass or not. If the original plate glass then I strongly suggest you replace it. Unfortunately, if you replace it you may have trouble finding the setting channel with the rubber flap.
merric33
The rear windows have the same flap that the doors do. ...and they let in just about the same amount of water.
The windows and all are in great condition.
I never found drain holes for the rear windows if my 33 two door sedan.
I believe the original setting channel had a horizontal flap that sealed the bottom outside of the window when it was up which would reduce the water getting into the car.
    The following users thanked this post: merric33
merric33
I am trying to find where the rear window drains are. The doors have drain holes in the bottom. The two rear windows currently are just draining into the rear of my car. Is there a drain hole that I plugged up somewhere?You cannot view this attachment.You cannot view this attachment.
