30 Plymouth parts/engines all resonable offers accepted
Started by GWR, October 13, 2022, 08:32:07 PM
GWR
I'm not getting any younger and have lots of stuff I will never use. Here is a list. If you can use any of it just give me a call at 503-939-9320.
30U frame (damaged, but reinforced), with complete front axle with backing plates and springs, complete steering gear with wheel (good), rear axle complete with backing plates and springs.
30 Plymouth rear end complete with backing plates and drums
30 Plymouth front axle w/springs, steering gear, and backing plates
30 Plymouth engines: U2332257 Complete with flywheel: U243631 Complete w/bell houseing, flywheel and starter:   U227832 Good block and crank: U232411 block with bell housing
33 Plymouth transmission complete with brake assemble - non freewheeling
several 30U transmission cases w/ gears (disassembled)
30 spare tire carrier
rear spare carrier for ??33-34?? Plymouth
2 trunion type driveshaft with u-joints
lots of other miscellaneous parts
Give me a call if you need any of this, Gary Rusher, 503-939-9320, Wilsonville, Oregon
GWR 30U Business Coupe
        67 Fury III 4drHT w/383
    The following users thanked this post: Out plowing
