36 cooling system
Started by djbsr, April 27, 2022, 06:34:33 AM
I don't believe that pressurized cooling systems were used prior to the very late 1940s or early 1950s. In any case, your '36 is unpressurized.
If you take the radiator to a shop be sure they know that. I had a shop nearly destroy the top tank on my radiator because they tried to pressure test it. The tanks ballooned out. Fortunately, another more experienced radiator shop was able to get them back into the correct shape.
djbsr
Does anyone know if the 36 ply. ooling system is a pressurized one ? If so , how much psi. ? Also need 1 head light bucket . TIA , Don
