Paint Detail
Started by mvair, November 20, 2005, 01:12:32 AM
I know some of this information was on the old board.? I need it again.? What were the original engine, transmission and accessory colors?? The list from the p15-d24 site is below.? What color were the generator bracket and generator adjusting bracket on a '41?? Also, the list below says the oil filler tube was silver.? What color was the oil filler cap?? Finally, what color were the various clutch and hand brake brackets?? (The ones that bolt to the transmission and clutch housings to hold the cables, linkage and support brackets.)? The items listed as gray below for the P15 were painted balck on my P12.? Those colors must have changed after the war?? I also checked the POC judging standards, but there's not much detail offered.
Paint Details
Silver
Block
Oil Pan
Head
Water Pump
Oil Pump
Front Engine Mounts
Mainfolds
Clutch Housing
Transmission
Oil Filler Tube
Dipstick Tube
Front Pulley
Thermostat Housing
Heater Bypass Hose
Black (semi-gloss)
Starter
Generator
Distributor Body
Wire Loom Holder
Coil Holder
Coil
Air Breather
Air Cleaner
Air Cleaner Steady
Breather Brace
Valve Chamber Vent
Valve Chamber Tube
Fuel Pump Shield
Fan & Pully
Oil Filter
Filter Brace
Steering Box
Entire Frame
Brake Master Cylinder
Brake Lines
Inner Front Fender Shields
Radiator Side Shields
Engine Dust Shields
Hood Lock Plate Brace
Horns And Bracket
Bumper Supports
Radiator Support
Radiator Cross Bar Under Body
Gray
Inside Floorpan
Underside Of Hood
Underside Of Trunk Lid
Front Stone Guards
Rear Stone Guards
Front Fender Center Panel
Grille Panel
All Fenders (Inside)
Inside Trunk Area
Trunk Hinges
Trunk Wheelwells (Trunk Side)
Backside Of Wheels Fuel Pump
Carb
Fuel Lines
Oil & Vacuum Lines
Accelerator linkage
Shift rods
