1950 Plymouth hubcaps on non stock wheels
Started by RC Drown, April 21, 2018, 11:27:52 AM
Any source for a set of separate beauty rings plus dog dishes for
original wheels??
I too have the rotating problem, but the stem covers hold on until now!
Greetings from Düsseldorf!
Go
Flathead
I tried everything to keep the full size caps on and gave up. The caps rotated while driving and one actually sheared off a valve stem causing a blowout. Luckily I was close to home. They do have valve stem protectors, metal sleeves, available but I switched to dog dish. I think I like the way they look anyway. Anybody wanta deal on a set of full size caps?
I don't believe that the older generation of drivers remember how problematic the full size clinch-on wheel covers were. Generally they were not a problem during city driving, well that is, except on hard turns that involved a rough road surface.
Myself I prefer the "dog dish" style of hubcap with beauty rings on the wheels.. Wm.
I too am late...
my Hubcaps fell off 3 times, twice in sight of the shop-
once on the way home from there at 75 mph on the Autobahn.
Luckyly it had not hit any car nor killed a bike driver ...
This time the cap was wrinkled to only shop decoration use.
  My friend Tom now refuses to put them back after any wheel related servicing
and puts them into the trunk :))
This was the 3.rd loss 2014:
[attachment id=0 msg=19057]
[attachment id=1 msg=19057]
The caps fit strongly WHEN- back on the hub- they result gap free!
This needs strong beats with the heel of the hand or a rubber hammer.
I never lost them in a curve
but or braking or because of the vibration at hi speed.
Greetings!
Go
Bob,
I know my contribution to your topic is a little stale, in any case I'll ad my thoughts.
I would suggest that you not attempt to "glue" the caps on, you might not be able to get them off when the silicon cures.
I would suggest that you reposition the attaching "teeth" on the hubcap so they get a good bite onto the wheel. A little work with a pair of pliers, or a plastic mallet could really make a big difference. The full wheel hubcaps are famous for coming off on sharp turns. Wm.
CHS
Looks Good Bob. If the wheel covers fit on tight I don't think it will be a problem. If you can pull them off by hand, then I would use silicone.
Last summer I got a heck of a buy on some non stock wheels for my Plymouth, I like the look very much, but I am thinking of adding some stock 15" 1950 Plymouth hub caps to the wheels.  I have test fitted them and they fit fine, but I was wondering if they will fall off when I make turns an such that would make the tires conform to the turns?  If that is so, what do you guys think of adding GE Silicone II to the noon, three, six and nine areas on each wheel before I actually put the hub caps on?
