1946 Ply Coupe Window Channel
Started by jdmaze, November 13, 2016, 10:07:27 AM
Sorry.  Had senior moment and forgot the attachment.
I found this drawing for you.  It looks like the rollers you refer to actually DO ride in the lower glass channel.
Does this photo help in any way ?
I can send this whole book to you if you want.  It is a body manual that covers your car.
jdmaze
Is it the 1/2" stuff with out the stainless steel bead (10-k-96)?
jd,
If you are speaking of the channel where the door glass goes up and down in, look at the
Restoration Specialties & Supply catalog. You can view it on line.
Also, there is a listing in the Dodge City Truck Parts catalog (on-line).
Good luck.
jdmaze
 I need to know the correct size of the window channel and where can I get them.  Thank you.
