1949 Plymouth Sway bar bushing kit
Started by Scott_W, April 05, 2016, 08:39:47 AM
Scott_W
Thanks for all the information. I will give him a call.
suntennis
Dave Kruse in California has made these bushings out of rubber and urethane. His phone number is  909-239-7932. If he has them they will be $35-$45. I put a set of urethane bushing in a 52 car and they do a great job. Tell Dave Hi from suntennis if you call.  To install the front or center bushings, they are kept in place by clamps that are spot welded to the mounting bracket. A 1/2 inch drill will do the job of removing the spot welds then just use bolts to reassemble.
Plymouthcranbrook
I believe that they are the old Atlas Obsolete Auto Parts people. If so they are good to buy from. I bought several parts from them in years past with good results.
Scott_W
Thanks for the link. I'll check them out.
I found this link on google, I know nothing about this business
http://www.moparmall.com/Steering-Front-Axle-Suspension-Parts-s/19.htm
You might also want to check with Andy Bernbaum and Len Dawson at Deception Pass Auto parts
Scott_W
Does anyone know where I can purchase a front end Sway bar bushing kit?
1949 Plymouth Special Deluxe Convertible.
Thanks.
