31 Transmission cluster gear wanted
Started by 31plymouth, January 13, 2016, 12:48:32 PM
 Do you know if Desoto is the same ?  I know someone who has a complete transmission
and I might have one too but it has the freewheeling setup.  I am the tech advisor for 1950
in the Plymouth Bulletin and more direct contact info can be found in the magazine.
31plymouth
I am looking for a 31 Plymouth Spur/ Straight tooth cluster gear.  I have two transmissions with a broken tooth on the cluster gear.  I am running a 32 trans now but would like to see if I could get one of the others fixed.
