Need 1939 201cid engine head
Started by g6001, March 25, 2006, 07:29:14 PM
g6001
Thanks to Lindsay McConnell - correct head, correct part number, now at machine shop for cleaning, maganflux and shaving - looks very good.? The POC Discussion Board comes through again.? Thanks? JNG
Jack Gallagher
1956 DeSoto Fireflite Sportsman Hardtop, 1964 Plymouth Sport Fury Convertible
 A number of cylinder heads will fit your engine but take care you do not use one from a 3 1/4 bore engine such as a Dodge or later Plymouth as you will wind up reducing your compression ratio.
Obviously it is best to stick with a 39 head but a Plymouth head from 35 to 41, 201 engine will work. You would be wise to check the part number with a reference book as a head removed from a 39 , 66 years later may not be what it ought to be.
  DPollock
g6001
I am searching for a 1939 201 cid L engine head - mine has a crack.? Please call 301-674-5431? Jack Gallagher, Bethesda, Maryland
Jack Gallagher
