Points for 1934 Plymouth==PE==new info
Started by , April 19, 2012, 06:20:39 PM
furylee
Todd, that would be my guess.  I looked up the IGS-4207 on this site http://www.hagensautoparts.com/search/?search=igs-4207
It shows the A-1/B-1 distributors.  If you click on one of those links, it shows an aftermarket P/N for the vacuum advance, but not the 1300795, which is probably the Mopar number for the advance.  Lee
37 Plymouth Deluxe Sedan
41 Special Deluxe Coupe
58 Belvedere Convertible
64 Fury Convertible
68 Fury III Convertible
Papillion, NE
I'm wondering if "Splash Proof Distributor" refers to a military Dodge (M-37), or a civilian Dodge Power Wagon?
Quote from: furylee on April 20, 2012, 10:11:40 AM
I typed that P/N in the site www.nosmopar.com and searched, and it shows up as a vacuum advance for 42-48 Chrysler/Plymouth/Dodge/Desoto.
Part#   Type   Price    Quantity   Description   CT                                            Vehicle                            YEAR
1300795   NOS   $90   3   vacuum Adv 2084841 959322 1135576   ABCETPDSC   42-48 Ply Dge Chry Des   42   48
1300795   NOS   $   22   vacuum Adv 2084841 959322 1135576   ABCETPDSC   42-48 Ply Dge Chry Des   42   48
The '38-'48 parts book numerical index does not show that number at all.
It does, however, show up in a table on page 98 of the '46-'54 factory service manual as associated with a Auto-Lite IAP 4102 A-1 distributor. Not clear if it is the vacuum advance part number or the distributor part number based on the table.
There is also a note on that table regarding part 1308206 for the Auto-Lite IGS 4207 B-1 that it is "not serviced, superseded by part number 1300795." So I guess it is a vacuum advance and it might be found on either of those two distributors.
furylee
64 Fury Convertible
Papillion, NE
Hmmm. That is a higher number than the 1120567 used on the '46-'59 Plymouth P-15 models. Might be an early 50's distributor... I'll look in my '46-'54 factory service manual tonight to see if it lists something that matches up.
OK,   here is info from distributor.   Chrysler part number is 1300795.     Auto Lite on tag.       Tag also says 'Splash Proof Distributor'.
It also has another number and a serial number(hard to read).
I need points for this distributor.  Any more help appreciated.
