40 Plymouth P10 Hood Chrome Strip
Started by 40Coupe, July 09, 2011, 08:53:15 PM
40Coupe
Thank you biggaadams! For the life of me I could not figure that one out. You have made life easier.  Bob
bigaadams
If it is like any of the other Mopar products, the trim has about 3 or 4 tabs that insert through slots between the hood halves..these are then snugged up by a bit of tension and then twisted to lock in place..to remove..untwist the tabs till they are parallel to the hood seam.I suggest grasping the tabs with a plier and pushing up and down a slight bit with to remove any rust/trask or paint bond and make them free to move so as not to kink your trim on removal..
40Coupe
I cannot seem to figure out how to remove the chrome strip that runs the top of the hood between the two 'hood wings'. Anybody know??
Thanks in advance.
