torquing cylinder head
Started by David Rainville, April 30, 2011, 02:12:41 AM
torque loadings are usually determined by the size of the fastener and the pitch of the threads. Should be able to look up charts on the web.
65 to 70 foot pounds, but mote important is the sequence which essentially radiates out from the center-most bolt.  Do it again HOT.  dp
GWR
Think I remember who, but not sure and don't want to give his name, but was told to do the heads at 70lbs torque. Replaced my head gasket and no problems.
Gary
GWR 30U Business Coupe
        67 Fury III 4drHT w/383
Quote from: Glenn on April 30, 2011, 10:33:36 AM
If you go to Tod Fitch's web site, www.ply33.com/Repair/torque , I think you can find the info you need. It pretty well give most of the info on torque values as known at this time.
SD Glenn
But not, I am afraid to admit, for the four cylinder engines. If the four cylinders used the same studs and nuts as the PC/PD I'd have suggested using those torque values. However the part numbers are different....
SD Glenn
SD Glenn
SDGlenn
David Rainville
What is the recommended torque valve for a 4 cylinder head?
