horn button wire
Started by TimT, July 08, 2010, 10:35:23 AM
TimT
thank you so much for your help, mission accomplished!
tim t
I am not familiar with '52s but on my '41, the wire passes down the hollow center of the steering column, through a tube in the steering box and out through an opening on the end of the steering box. I passed a stiff wire up through the steering box and out at the steering wheel, fastened the horn wire to the end of it and pulled it back down through.
Hope this helps.
TimT
my 1952 plymouth was missing a horn button and wire, i have all parts together but can not fiqure out how to run wire through steering column and where it comes out of steering column. need some advice
thanks
Tim T
