'50 Plymouth Rocker Molding
Started by Lew, June 16, 2010, 12:47:02 AM
bigaadams
the trim will "snap off" at the clip with a bit of pressure try to do this without using a screwdriver as it will likely want to kink the lip of the molding..I like to use two puddy knives..I to back and protect the body and the other to gently exert force on the molding..pushing up from the bottom of th clip will help a bit..the retaining clip is held in the square slot by bending the metal tang..you can loosen the mechanical contact of the tang and carefully remove the clip..if not severly rusted, you may be able to reuse them..these are getting somewhat expensive should you find them at all..
Would like some advice on how to remove the chrome rocker molding and clips from the square holes in the sill body panel of a '49 or '50 Plymouth? We don't want to chance damaging the molding with prybars, etc.
Thanks.
