6 volt overdrive relay
Started by jd2ksilver, March 21, 2006, 12:40:13 PM
jd2ksilver
Thanks Harold, I will do that.
Everything is in ready to roll.  Just need that relay, so I guess I can take it off the jack stands and drive it as a regular tranny until it shows up.
Thanks again,
John
1952 Plymouth Cranbrook 4 door sedan
2003 Dodge Ram 4X2 1500 Hemi Longbed
John Davies
Mountain View, California
Captain Cranbrook
There are many mechanical parts still available for your '52 through retail parts stores.? The trick is getting a parts-person to look it up in a paper catalog.? You may want to check out www.p15-d24.com.? It's a very active website focussing on 1946-49 Plymouths and Dodges, but also has a lot of info and discussion on flathead-six Mopars through the mid-fifties.? There is even a parts number section showing modern numbers for older Plymouths and Dodges.
If you have any questions, write me directly at:? ?cranclanAToptonlineDOTnet? ? (put the proper symbols in the email address....this thwarts automated email-address harvesters)
Harold
jd2ksilver
Update,
Found one in Oregon, for a Hudson.
Wish I could find a parts source closer in the future, at least in CA.
John Davies
jd2ksilver
Hi all,
I am looking for a overdrive relay for my 52 Cranbrook.  I do have a 12 volt relay but it wont put out enough power to close the points with the six volt system.
Any part number, vendor or any info at all would help.
It is a 4 prong, isolated ground, fused type.
Thanks in advance.
John Davies
