1949 Plymouth P18 Deluxe - Wheels ... Rim, Cap, Paint, Trim
Started by 49plymouthclubcoupe, September 18, 2008, 11:52:02 AM
49plymouthclubcoupe
Just adding a photo that may prove useful to someone someday .... its a close-up of the pinstriping on my P18 Deluxe with a ruler for reference.
John - Colorado
There is a place in N.Y. called Finesse Pinstriping that produces stencils (tape) for painting stripes. The tape may be pliable enough to fit the wheel curves depending on tape width but I have used it only on body surfaces. They have a variety of styles and also have small cans of enamel to mix your own colors.A small airbrush works great or one can use a pinstriping brush. They have a website with prompt customer service.
LR
49plymouthclubcoupe
Thanks Jim.....appreciate the photos and the great ideas.   It does look like a little practice would be of real value.
John - Colorado
Jim Yergin
Here's how I pinstriped my wheels. Instead of using a Bleugel stripping tool (expensive) I found a Master Paint Striper at http://www.dickblick.com/zz289/08/ for around $16. It came with both the 1/16th inch and 1/4 inch stripping wheels I needed.
I also got the One Shot sign painter paint from the same source. The reference information I had said that the pin stripes should be "gold bronze." I couldn't determine that exact color so I just used gold.
I clamped an extra front wheel spindle in a vise and then placed a front brake drum with bearings on the spindle to create a turntable. With the wheel on the drum I used a guide wire to follow the outside rim as the wheel turned.
It took a little practice but it was easy to wipe off my mistakes while the paint was still wet. Though not perfect, I am pleased with the results.
Jim Yergin
Don Pohlmann
No, mine is original, I am going to havde the car painted this winter and like you, would like to have the same stripes on the finished product.
49plymouthclubcoupe
Quote from: Don Pohlmann on September 22, 2008, 03:12:02 PM
Your wheel and hubcap looks identical to my P18 DeLuxe.
Don, have you ever tried to reproduce the striping?   It seems to me that if you could hold your hand steady enough you could spin the rim and reproduce a similar pattern.  I've never tried to stripe these things before.   Any thoughts?
John - Colorado
Don Pohlmann
49plymouthclubcoupe
John - Colorado
Jim Yergin
You can find good information on the P15 wheel stripes at : http://www.oldmopar.com/oldmopar/colorchart.html
I think the same info probably applies to your '49. I followed it for my '41 P12.
Jim Yergin
49plymouthclubcoupe
Here's a photo of what I believe to be an original wheel, cap, paint and trim combination on a 1949 Plymouth P18 Deluxe.? ?I'd like others to comment and either help me confirm my belief or share other information as to what a correct original/restoration would look like.? ?Note the three stripe white on the rim and the apparent body color paint used.? Did they all have the three white stripes?? ?Were the rims always painted body color?
I also believe that there were two primary hubcap types used with the 1949 2nd series.? ?One is the style shown in this photo that was a center cap only.? It had impressed block lettering of "PLYMOUTH" with the letters painted dark red.? ? Sometimes these center caps were used in conjunction with stainless trim rings that gave a full cap look using the two separate pieces.? ?I believe there was also a full cap used on these 1949 2nd series that was also stainless but used raised, unpainted blocked "PLYMOUTH" lettering.? ?
Yes, No .... other photos?
John - Colorado
