Directional signal switch needed for '55 Savoy
Started by Mowog, October 12, 2008, 04:07:15 PM
CHS
If you have not found one yet, I suggest you keep an eye out for one on ebay. They come up every once in awhile. I purchased one from Len Dawson about 25 years ago. I don't know if he still has any.
Mowog
Hello,
The original turn signal switch in my 1955 Savoy has apparently given up. This is the actual sealed switch unit in the steering wheel. Mechanically everything works, but when the ignition is on it flashes the left turn lights regardless of the lever position. All lamps, connections, and the flasher unit are in working order.
Does anyone have a working switch that they would sell , or is an after market switch available? Is it possible to repair the original unit? Any help would be appreciated.
David
