'35 5-lug bolt pattern/size?
Started by wretched4one, February 11, 2010, 12:42:52 PM
wretched4one
Thanks. I believe it is 5 x 4.5"/ 5 x 114.3 mm and bore is 2 3/4" or 69.8/70 mm.
As I understand it, its the same as for an Mopar passenger car from sometime around 1930 up into at least the 1960s, excepting the smaller things like the A body.
The offset between the centerline and the hub changes a bit though.
wretched4one
Anyone know off the top of their head what the bolt pattern/size is on the '35 5-lug wheel?
Thanks, Greg
