Need a head gasket for a plymouth truck
Started by Big Matt, December 03, 2009, 12:53:07 AM
Matt
did you tell them it was a long block , it seems by the engine # you have a commercial engine , apart from that if you definately have a long block just reorder reorder a after 39-early fifty,s DeSoto or chrysler gasket they will fit witrh no modification , chrysler didn,t change much with there six,s over the years , you might see that with the later gaskets there is a slight difference in the water hole ?in the front of the gasket , don,t worry it will work ok.
Rex
Big Matt
Have a 1938 Plymouth Truck with a long block engine numberT38-2458 not sure about the 2458 part. Have been to Roberts twice and Then and Now only to receive the wrong ones. Just contacted Atas Chrys.com I'm waiting to here from them. Any help. Thanks Matt
