Need exterior trim clips for 41
Started by notdavidspade, August 02, 2009, 12:03:35 AM
Bender
Try these people. They can and will even make them for you if they don't have them and you have an example good enough for them to use as a pattern.
Good people to deal with,too.
http://www.restorationspecialties.com/
Looking for any 33-34 Mopar sheet metal parts
Looking for any 33-35 Dodge or Ply pu sheet metal or chassis parts.
Looking for inline 4x2 intake manifold for a DeSoto hemi.
Lindsay McConnell
Steve,
Are you looking for original type clips?
If so, the description given is not clear...Then again, maybe it is just me.
I do currently have the original arrowhead clips for the hood trim,plus the two ends that are attached with a nut, and a very limited supply of the "T" type clips for the upper reveal moldings. The surrounds were not really sold as a separate "clip". They came mounted in the moulding. These can be made with little effort though. You also may have some luck at your local parts store with a universal style clip.
notdavidspade
Hi All,
I'm in the process of putting my car back together and could use some trim clips.  Need the wire ones that hold the side stainless on the hood and the stamped sheet metal ones that hold on the small trim to the side of the cowl, between the hood and the door.  Could probably use some that hold on the heart shaped grille pieces too.  Let me know what you have.
Thanks!
Steve in FL.
