36 plymouth Body Mount Question
Started by ParkBear, May 28, 2008, 08:56:17 PM
36ply4dr
well i got a few pics. Maybe this will get you started. If you give me specific locations I can maybe hunt them down.
ParkBear
Mike
1936 plymouth P2
Currently Being Rebuilt after being in pieces for 18 years
36ply4dr
I took a quick peek under my car, a '36 4 door plymouth.  when I get more time I'll crawl under there and locate the mounting points and see if I can get some pics for you.  If you didn't already know there is a gentleman named Tom Bryant who has a rebuilt 36. He could probably tell you exactly what is needed there.I'll send you his number.
ParkBear
I have am trying to restore my 1936 plymouth P2. I am coming to the point where I need to put the body back on the frame. It was disassembled years ago so I have no reference. There are 2 bolt patterns that I can see on the frame some are oval and some are round. There are also studs that come off the frame that kind of look like a raised washer on a pin (if that makes any sense) I have a parts book and it shows 9 different mounting styles. There is one stud in the frame at the rear cross member. It appears that there was rubber near the raised pins by the impression in the floor. I'm at a loss as to where to buy the rubber and how it all fits together.  Do some have bolts and some have studs? I'm assuming there is rubber that fits between the body and the frame but does every bolt have rubber or just at the raised tabs. Is there rubber inside the car?
I have some time before I am ready to the body on but I am just trying to research it so I am ready when I get to that point. Any help would be appreciated on how this goes together and where to buy. Alignment is another hurdle I will tackle at some point.
Mike
Mike
1936 plymouth P2
