Rear axle shaft torque,'37
Started by Pandanom, February 29, 2008, 04:20:32 PM
Pandanom
Quote from: John Hendricks on February 29, 2008, 06:18:32 PM
Around 150 ft lbs, as i recall.? Don't forget the cotter pin.
Thank you for responding John! On my VW bus with a fully splined shaft and reduction gearboxes the torque is 250 ft. lbs. so 150 for the Plymouth sounds about right. I'll go with that.
James
Around 150 ft lbs, as i recall.  Don't forget the cotter pin.
Pandanom
Does anyone know the torque for the 1 1/4" wrenching size nut that holds the brake drum/hub on the rear axle of a '37 P-4 4 door sedan? My manual only says "tight".
Thanks,
James
