Seals
Started by Carmen, January 27, 2008, 07:14:29 PM
Wayne
#9
Carmen I have 2 of the rear axel outer seals (grease retainer)? ...but they dried out many years ago, they have no #s stamped into them, but the box says replaces # 648240 #660154 #660156 #651720 Plymouth- Dodge- DeSoto- Chrsyler 1934-1942.
These were made by.. TRAUTNER MFG. St. Paul Minn.? I thought mabey these #s would give you a starting, reference point.
One of my books says that they are the same through 1948 but I don't know for sure.? Hope this is of some help.? Wayne S. California
P.S.? ? ? That is the only seal on the axel housing, there is a paper gasket and a shim that is used for axel end play.
Another thought-I don't know how much or how often the vehicle has been driven-but is the vent for the rear axle patent?  If u do need a new outer seal, there is an ad in the bulletin for some from a fellow in Oregon.  I put a set on my Ply PU and 32 PB.  They are made out of a modern polymer, and at least so far have worked fine.
Carmen
Per chance you wouldn't know the inter axle seal number would you? As long as I am going to get dirty I may as well get very dirty.
Carmen
The rear seal is NATIONAL 5797 which actually bears on the brake drum hub. It is often sufficient to change only this seal at the rear, although the presence of large amounts of  differential oil may indicate the inner axle seal needs replacing.
It has been some years since I purchased any 5797s which were at the time made in Mexico.
Carmen
Is it oil or is it brake fluid on the rear tire?
Carmen
I guess I am looking for the seals that between the bearing and inner part of the axle which does not oil leak into the brake drum area. I have them on the army jeep and truck. There is oil on my left rear wheel. I assume that it is coming because the "SEAL" is leaking.
I hope that I explained it
Carmen
40mopar
What seals are you referring to.  I've got a 1940 P9 and may need the same thing, but don't have a point of reference to know what you're talking about.
40mopar
1940 Plymouth Business Coupe
Nashville, Tennessee
Carmen
I just picked up a 41 Plymouth Special Deluxe. I need to know where I can get the seals for all four wheels? Does anyone have the NAPA part number for them?
Carmen
