Speedometer cables
Started by David Rainville, November 12, 2007, 12:52:01 AM
David Rainville
David, thanks for your response, it's much appreciated
If you have a friend who has an early Model A Ford, check the cable used in it. There were at least two and the earlier one just might work in the Plymouth.  If so, it is available as a reproduction part.  My recollection is hazy on this but it is worth a look.
David Rainville
I'm in need of a 31 speedometer cable, are there other years that are the same size? It would help me broaden my search if I knew what other years would fit.
Thanks in advance for any helpl
