Who has electronic voltage regulator experience
Started by Go Fleiter, September 26, 2007, 01:01:57 PM
Dear David, thanks! These experiences are this forums value!
I will get a spare Regulator assembly and not try Electronics here.
Greetings! Go
If you are seriously contemplating these changes then you would be better off with standard components such as the Chrysler alternator and external electronic regulator and a slant six electronic distributor which requires only minor machine work and the substitution of the distributor shaft from the distributor in your car.  The down side is your six volt components such as the top motor, windshield wiper motor, radio , heater and overdrive controls which are all difficult ( but not impossible) to modify.   Believe me, simply replacing your V-reg with a new or rebuilt unit is the easiest fix.  All 6 volt Chrysler product regulators used from mid 1950 to 1955 are interchangeable and can be recognized by the battery terminal on the opposite side from the field and armature terminals.  I have found the original Autolite units to be very reliable but have had trouble with modern replacements.
Dear all,
I?m thinking of changing the voltage regulator to a n electronical device, hidden in my spare regulator case, whose contacts are burnt out. Any Experience?.
btw. my spare distributor unit (P21 unit?) will be modified to Pertronix ignition.
Greetings! go
