Control Arm Bushings ?
Started by darren, July 23, 2007, 08:43:59 PM
darren
Today I ordered lower control arm repair parts from Roberts Motor Parts  I did so I can ask him , he says he does not really sell alot  ,, Also I think the reason is  ...I doubt they will ever fall out in anybodys life time ..... but I think if every one really had there alignment done to specs would be suprised to really learn the camber is off.. most alignment shops willl say...if u don't put a lot of miles on it why bother?   once mine are installed I will let u know of the improvement DANiel
57plymouth
I don't know what is causing it, but the passenger side upper control arm bushings on my 1957 get eaten up pretty quck.
darren
My bushings on my 40 Plymouth P10 4 door sedan  on the drivers side (left)  all seemed to of had a lot of play or lets say  worn out play, is it or would that be a common item that gets a lot of wear through the years ?
I put all new frt end parts on and new springs  king pins etc. my SAI (alignment specs)  was off and sure enough lots of play in that lower control arm bushing  thanks for letting me know DANiel
