1939 Plymouth parts book
Started by William Perry, December 08, 2025, 04:27:29 PM
wintbg
Greetings William, In the parts book the window wings used on Chrysler Corporation convertibles are called "side wing stanchions". Also needed are the pivot brackets that hold the glass and clamping blocks to hold the pivots. The lower pivot bracket is slightly longer than the upper bracket. The same stanchions, pivot brackets and clamping blocks were used in 1937,38 and 39. The 1940 and 41 models used the same pivot brackets and blocks, but the stanchions have a slightly longer tail where they attach to the door. I hope this helps.
764184 right side stanchion (1)
764185 left side stanchion (1)
764180 upper pivot bracket (2)
764181 lower pivot bracket (2)
764186 upper clamping block (2)
764187 lower clamping block (2)
William Perry
I am looking for the part numbers for the pieces that make up the wind wings assemblies for the 1939 Plymouth Convertible. If anyone has a parts book that includes this information it would be a great help. Also does anyone know what other models and years use the same wind wings.
